gps navigation
2 replies · 1,370 views · Started 13 February 2004
Hi All
I am thinking of buying a gps navigation system. For use in the uk.Is there a system available for the 9210? if so have you used it and can you recommend it? If not what would you recommend?
thx
bob
Hi Bob,
a year ago I bought Nokia's LAM-1 and it works just fine.
Support from TomTom is bad though, no reply on questions whatsoever.
I use in the car mostly. Used during vacation in GB, no problems.
