How to Cut & Paste
3 replies · 2,599 views · Started 13 February 2004
I have been trying very hard since I got my P900 to cut and paste numbers, names, addressed etc.. within a contact field to another field or to another totally different name within contacts.
How do I highlight the field and do the above function?
I manage to highlight the field sometimes but it comes quite accidently and when I try it again😡 😕
I give Up, anyone out there who has successfully done this?
Hold the stylus on the screen until you get a flashing cursor you can then drag the stylus across the screen to highlight text which you can then cut and paste.
Hey Chewie,
Thanks a BUNCH,😃 😃 😊 , Man. You really solved a big problem for me. Imagine, I have almost 12,000 contacts and having to manipulate numbers around😱 😱 🙄 . Phew!!! thanks again man.
