I have used Bluetooth to send a file from my desktop into my 6600, and it sits in the inbox on my MMC card. I thought I could use Forward, but it does not see the Inbox on the MMC.
Any ideas how I can more the file to a specific folder? I have eFilemanager.
go with your file manager to MMC and then to System-> Mail, find your file and then cut,paste to your destination...
Thanks for tip, and it shows promise.
Now this may seem like a dumb question, but how can I find the file? I have over 2000 texts and emails on that mmc card, and have no idea where the mail folder is. Th
You might want to try this app, called Forward. I use it all the time for files that the Messages app doesnt recognize, mostly .txt and .gz books. It will automatically find attached files in your messages, and allow you to copy them to another place on your phone, like the MMC.
It is located at:
www.compsoc.man.ac.uk/~ashley/forward.sis
Hi and I do have the Forward application installed and it sees lots of image files, but I only have one msg in my inbox, and it does not see the file in that message. Also I have no idea where these image files either.
