Start up problem
2 replies · 1,791 views · Started 13 February 2004
Hello,
I'm having a big problem with my n-gage,
i did a reboot with fexplorer and when i try to turn it on again i'm getting the usual screen,
with nokia logo at the buttom and after a few minutes i'm getting a white screen and that's it!
i trie to change cattary and MMC but nothing it just won't start.
if someone knows what is the problem please tell me i would really appreciate that.
thanks
Ok, the cause of your problem is that
A) your n-gage os was formatted.
B) your n-gage os was corrupted.
C) you moved the os somewhere and the system can't find it.
this can happen with the file managers, i know, it actually happened to me last night.
i fixed the problem very easily (hehehe...).
i took my n-gage back to gamestop where i bought it and my warrenty and got it replaced. Other than that one solution, maybe pc suite can help
Thanks for the reply,
well all i did was a reboot with fexplorer so i dont think he moved or erased the OS but who knows.
i guess i must take it to the store i bought it from and i still got the warranty so i'll get a new one too.
thanks
