otb to ota picture message
1 replies · 3,823 views · Started 13 February 2004
Hi ppl ..
Well .. i have a 3660 and an mms service but since i live in the UAE my &^$%*% service provider does not have the facility to send mms out side UAE thats like india and all so had to send an mms for my broz b'day. now my problem is that when i make Picture Messages in LOGOMANAGER they are saved as .otb and nokia as i presume has a .ota extension .. so is there any way i can make Picture messages and send it to my nokia 3660 ?? Anything like logomanager .. Plz help .. badly need some advice.
Thankx in advance .
It's easy. You just have to change the file extension from .otb to .ota manually in Windows Explorer, then send the file to your phone using PC Suite. Make sure though that you have allowed viewing of file extensions in Windows Explorer (Tools---Folder Options---View) before you start renaming file extensions.
