Sup peeps, I was just wondering if anyone has the mms and wap settings for their nokia 6600 but who use T-mobile as their network. I've tried 2 use the 3650/7650 settings but I wasn't sure whether you have to fill in the advanced settings such as Primary name server, secondary name server, proxy serv address and the proxy port number. Can anyone help me pls thnks (all the other networks have these settings why can't stupid T-mobile stick with the times)
T_mobile mms/wap settings??
Call support and they will send your phone the config settings. Then all you do is 'Save as Settings'. That's what I did and it now works perfect! 😊
Thanks for that macagent
If anyone knows how to do these settings manually please post them up cos I think a lot of other peeps may want to know just in case.
By the way macagent was it the 150 number, for customer services that you called, and then you was put through to a technician. How do they send the settings to you by email or txt??
Hi all, Just called T-Mobile this morning about my 6600, to get the settings sent to me via TXT message.
Got the Wap going on GPRS but not the MMS as yet, the guy is calling me back in an hour or so about that part, if he calls.
however if you need the GPRS settings here they are -
Change these in Access Points...
Connection Name - T-Mobile GPRS
Data Bearer - GPRS
Access Point Name - general.t-mobile.uk
User Name - user
Prompt Password - No
Password - wap
Authentication - Normal
Homepage - http://wap.t-mobile.co.uk
Connection Security - Off
Session Mode - Permanent
Then go into Options, Advanced Settings
Phone IP address - Automatic (this can be got by entering 0.0.0.0)
Primary name server - 0.0.0.0
Second. name server - 0.0.0.0
Proxy Serv. address - 149.254.201.132
Proxy Port number - 8080
Then in connection Settings, GPRS
GPRS connection - When Available
Access point - wap.t-mobile.co.uk
Then go into Services on main menu, Options, Settings -
Default access point - T-Mobile GPRS
Show images - Yes
Text wrapping - Off
Font Size - Normal
Default encoding - Automatic
Cookies - Allow
Conf. DTMF sending - Always
Wallet - off
Long winded I know but it works for me...
Will let you know onthe MMS thing in a bit.
Jester 😎
Hi again,
Just got of he phone with the T-mobile Guy and guess what.. woo hoo😃 my MMS is now working..
Though He did say that I had a setting in my profile at their end that was missing also
However the Settings are as follows -
go into the Main menu, Tools, Settings, connection, Access points, OPTIONS, New Access Point (use default Settings)
Connection Name - Picture Message
Data Bearer - GPRS
User Name - user
Password - (leave Blank)
Homepage - http://mmsc.t-mobile.co.uk:8002
Proxy Serv. address - 149.254.201.135
Then go into Messages on main menu, Options, Settings, Multimedia message
Access point in use - Picture Message
Multimedia reception - Always on
On receiving msg. - Retr. immediately
Allow anon. messages - Yes
Receive Adverts - No
Recieve Report - No
Deny report sending - No
Message validity - 24 hours
Image Size - Large
you should now be up and running,
Don't forget thought that T-mobile have to activate Picture Messaging on your account from their end.... Dial 150 for customer services.
Hope this helps you all out, it sure helped me.
P.S - I had these settings sent via Text Message by T-mobile but that way didn't work for me... So we just input them manually over the phone.
Jester 😃 😃 😃 😃 😃
Hey Jester that really really helped. T-mobile really needs to keep up to date with it's phones that way we could just get them settings from their site but thats not the case. Thanks again yeah much appreciated. 😃 😃 😃 😃
glad to help
Jester😎
