Parted company with mine in July. I'd had it for over a year, must have been one of the first ones out.
I still liked it, but decided to sell in anticipation of the "soon to be released" P800 or 9210i. Below are my list of gripes that helped it go. Just to clarify, I liked it but didn't use it as often as I would have had these been resolved. Every device has its "issues", you get to know them after a year. Maybe all addressed in the 9310 (though I won't buy it, but will wait for the 9310i 😃 )
Reasons for selling it:
Lack of USB, file transfers were slow, hassle. Sync. for contacts, calendar was fine but email was slow.
Also related to the above, removing/replacing the MMC felt a little delicate. Kept worrying about breaking the access door. OK for occational use, but would not be happy doing it 100s of times while not taking care. (Not snap in snap out). Now if it had had USB, would not have had to do it often anyway.
No Opera (without Out of Memory issues). Addressed in 9210i
Lack of Executable memory/out of memory issues. Possibly addressed on 9210i (better memory management), would have been better if they just stuck another 8 Mb in there.
Sluggish opening apps etc. Faster processor would have been nice. Again possibly adressed in 9210i with faster memory.
No lit keyboard, I used to use my IPaq in bed with the lights out (wife was not happy). Difficult with the 9210.
Lack of Automatic file syncronization. Major gripe with the Sync. software. No way of saying sync or copy the following files on every sync.
Bluetooth would have been nice, but since the phone is built in, not a major loss. Might have got round the lack of USB though.
GPRS maybe, but it is only just starting to approach affordable(ish).
A little on the large side, but if the other issues were resolved, I could live with that.
I didn't miss a touchscreen at all, quite liked not worrying about smudge marks on the screen.
Now for an unusual one that probably really made me sell. Lack of a 3rd party Twin Sim convertor. I have 2 Sims, 1 work, 1 personal. Having to open the flip cover, remove the battery, change sim and then close it all and wait for the device to reboot was prooving too much hassle. With a normal phone I just got a twin sim convertor or battery and problem solved.
Anyway, 9210i is out but doesn't address some of the above.
Primarily, no USB or Bluetooth, so sync. and file transfer still an issue, auto. file sync. issue and the twin sim issue.
P800 is almost here, but still have a couple of concerns.
Doesn't have the hi-res screen of the 9210.
Still does not appear to sync. files. automatically.
Concerns about lack of volume sales (relative to standard phones), hence twin sim option not likely to appear for some time (If at all). Looks from photos like the battery needs removing for sim changes, hence I get reboot delays.
Now Work have given me a Bluetooth enabled 6310i for which I have bought a twin sim convertor. So now I'm looking at getting just a PDA with Bluetooth.
Penny for your thoughts.
Zuber
