Does anyone know how to use the thmeme studio? Primarily, how do I get my custom .bmp images in there? The Browser only seems to recognize jpg files?
Is the 6600 Theme Editor app better? Easier?
It should reconize .bmp in exactly the same way as .jpg thru browser!
Havent tried the other theme prog,Studio is fine (slow but fine) i guess its just a case of which you get used too!
The unoriginal theme editor for 6600 is not as easy to use as the Nokia Studio.
I have both,..but must admit, that theres too much "guessing on what to do" in the unoriginal one.
Nokia's Theme Studio only have one disadvantages in my opinion,..its far too slow on an XP machine,..hope they will release an Xp compatible one 😊
BR
Jan
Can you give me a quick run down on how to get updated images into the theme. I can create some awesome UI, just got to figure out this app 😉
