Theme Editor for US buyer?
2 replies · 2,181 views · Started 15 February 2004
Is there a way for a US buyer to get Theme Editor?
Does anyone already use this? How is it compared to Nokia's java garbage?
Hey...
For a few Nokia isnt good...but most of them really like it...its cooll... & believe me.. most of the themes done out there are all compiled in Nokia Theme Studio. Besides... the Nokia Theme Studio will know what Hex ID's should it give for the installations & u'r theme too.. I suggest you should really give it a try.. A before hand note:
Just in case..it dosent work for you in WinXP.. right click on the istaller file, choose the compatability tab & set the compatability to run as on a Win2k Os...then start to move around it...
If you still need the Theme Editor (italian Author), you could still get it from his site.
Cheers
Marirs
HI!..
Sorry but the Nokia is the best by now...
i use under XP Pro and work perfect... sometimes a little slow to response.. that's all...
cya!
