i mean can i take out the wallpaper from the theme and save it as .jpg or in any viewable format ????
Taking out wallpaper from theme ??
Yes you can, it is fairly straight forward to take a .sis theme, break it apart and view all it's components used in the make up of that theme. Eg. the icons, backgrounds, colours etc.
First what you need is a program called 'UnMakeSIS' from here :
http://mitglied.lycos.de/atzplzw/
Then find yourself 'MBMWizard', sorry I don't have a link for this. It's in this forum somewhere so try a search for it.
The Unmake SIS splits the theme's .sis file into two files, the one we'll then use is the .mbm file.
Open the .mbm using 'MBMWizard' and this will provide a list of all the .bmp files.
Click 'select all' and 'save as' and all these parts will be saved. Then it's just a case of opening them using your favourite painting package.
Hope this helps mate.
Ian
Or just save a screen shot using the theme of choice!😊
thankz coolice :P
Your welcome mate.
Elton had a good point, or just a screen shot.
Depends how much of the theme you want.
Have fun.
Ian
screenshot ............ how to capture a screen shot ??
Get SeleQ and use this by pressing pencil and joystick with the app running in the background,there are plenty other apps to do this but Seleq is the best screenshot quality!😊
