no agenda view?!
4 replies · 1,830 views · Started 16 February 2004
has anyone found an organiser that allows you to jump directly to your daily agenda from the Go To menu? Handy Day almost does it but launches the whole calendar, not just the current day. ive been led to believe that it just aint possible on the series 60?! thats a bit of a shocker if true 😞
ta
The standard calendar does that.....
Open the calendar app, select options, scroll down to settings, select, then change default view to day view.
D
you can buy Task Manager and assign Calendar with the Day View to any key Direction you want.. i think that's the fastest way to get there.. 😊
