Skins for my a920??
7 replies · 3,753 views · Started 17 February 2004
The A920/925 runs on UIQ 2.0 which does not support skins/themes like UIQ 2.1(SE p900) but if you can install Tracker on it,you will find loads of themes for it.You can get Tracker from www.symbianware.com
@ GhostDog, I think figifigi is after diffirent phone skins that change the look of the buttons on the A920
lunchbox buttons
Anyone any ideas on how to make your own skins? I can handle the photoshop side, it's creating the skin file to put on the phone which is the problem. Any pointers?
Cheers,
Welly
Hey, I'm newbie in here.
Finally i found this forum.
Is it possible to install software from P800/900??
Cause i heard that the OS is the same.
Any suggestions guys??
Cheers,
k4nch1
