Okay i need help with getting the MSN Messanger on my 6600.
I have tried both Agile Messanger and IM+. I even registered with IM+ and got nothing.
They just wont connect even if i try everything. But strange thing is AIM that comes free with the phone works perfectly. :'(. Someone please help me. Thank You
The latest Agile Messenger works perfectly 😃
Are you sure you are using the new 6600 specific version ?
Hmm after checking i see that i DID get the correct version.
One thing i was wondering when signing in do i use username as:
wo33er
or
[email][email protected][/email]
And anyone else having problems ?
The AIM that came with the phone?
Where can get this?
Mine was on the default Nokia card waiting for me
Your correct login is your passport account, that is, your ENTIRE e-mail address:
God Dammit why wont it work !
hey,
i also try t0 connect with mobile internet by grps, when i connect i get an error on my screen like: failed to connect to msn service, please verify your username/password/internet connection.
ik put in my whole address and password, connected by grps but only error's
can anyone tell me some more about this program?
I@m not too clued up in the ways of the 6600 - only got it on Saturday - can anyone give me pretty detailed instructions on how to download agile onto my mobile phone? I don't have a bluetooth / infrared port on my pc yet, so can't transfer the file like that. I have some webspace however, so could possibly download it from there?
all help much appreciated
HI!..
i was using the last version of Agile Messenger... but
now don't show the online contacts... so i can't send any menssage to them 😞 ...
Now i am using TipicME again...
cya!
I got the same problem and mailed agile crop. about it.
Some people can send me a message, but they do not show up in my (empty) contact list.
Aplication looks good, buts does not always work correctly.
I am going to try tipic now.
I get the message "Failed to connect to MSN service. Please verify your username / password / internet connection."
I am using O2 WAP to connect as that works for email.
This is with |Agilemessenger.
Any tips please?
Where can i find 'topicME'?
Right ladies. I had the above problems and this is how i fixed them.
1. To connect if you have GPRS on 'always on' it wont work, u need to change it to 'on when needed'. Then when u select what you want to connect with dont select GPRS selct wap or anything else and then it will say 'Using connection on atm' THEN for sum mad reason it seems to connect for me.
2. To see contacts online the only way that seems to work for me is if they sign on !. If there already on as you come on.. you wont ever see them, but if they sign off and sign on again u see them.
(I just told all my fav mates that when my name is set to 'away' i will be on my phone and log off then back in to speak to me).
hope this helps - Wo33eR
