FREE Theme Editor
15 replies · 6,887 views · Started 18 February 2004
VITO ThemeEditor is a FREE for non-commercial use PC-based application that allows you to create your own themes for using on the P900.
Variety of settings for both Flip Open and Flip Closed modes, options for editing sounds and screen saver bring endless opportunities to customize your P900.
Created themes can be saved as a single file and transferred to the P900 or exchanged with your friends and other people.
Preview is available for all windows, and selected screenshots can be saved as .jpg files.
The program is FREE for non-commercial use, however the commercial license shall be purchased if you are going to make money using the software.
Download: http://vitotechnology.com/products/P900_ThemeEditor.html
I's a great product and I (and a lot Mac users like us), too, would like to see the same thing - an OS X version is much more appreciated.
I was trying to use this theme editor to present myself a new theme but found unable to set a background picture for the drop down menu which comes under �Flip Open Mode�; it�s taking the value from the �Color Scheme� in stead . When I set a drop down bg picture using the set button, it�s taking (and showing as well) the picture but after saving the theme it just showing the color from Color Scheme. Any idea what�s wrong?
Thanks in advance.
SEP900,
Please don't use spaces in the file names for background pictures.
Hope it helps.
Pad wrote:SEP900,
Hope it helps.
yup, I didn't actually. I just used a name like: bg_drop_down.gif or something similar but no joy. Is that okay?
underscores should be fine, however beware of spaces! 😊 And make sure you have the latest version of ThemeEditor installed - v.1.2.
Pad,
Many thanks for your reply. Just to let you know that I'm using the leatest version i.e. 1.2 indeed. Any other thing do you think might be the problem?
The theme looks great! Just don't forget not to use spaces in the file names! 😊
Pad wrote:The theme looks great! Just don't forget not to use spaces in the file names! 😊
Thanks!!!
Any idea how to take the original screenshots of the created theme; like for example � to show �Vodafone� (my operator) or whatever actual in stead of �RUS SCS�?
