I just got a cable from ebay. hasnt got no software withi it,
so im lookin for some advise on safe programs 2 use to connect my 6600 to my pc.
any 1 point me in the directions of programs
thx
thx
Originally posted by dgo
I just got a cable from ebay. hasnt got no software withi it,so im lookin for some advise on safe programs 2 use to connect my 6600 to my pc.
thx
I think you are in the WRONG forum. 😃
The 6600 does NOT use a cable to connect to a PC. 😃 😃
I think you are talking about a Nokia 6150 😃 😃
No he is not,these cables exist since the 7650 but they've never worked since there is no software for them.
So where do they plug into the 6600 ?
The charger socket ?
The earphone socket?
The microphone socket?
The MMC socket ?
Somewhere else ?
I have never heard of any such cable.
See for yourself:http://www.gsmdirect.com/shop/Nokia_3650_Data_Cable.htm
not sure if they work with series 60 but they worked with my old nokia 3510i that i connected using a similar cable, but perhaps Oxygen Phone Manager II (OPMII) or MobiMb (both are shareware i believe?) might do the trick. Search Google for it.
It's about the same price as a Bluetooth adapter, so I don't see any point in bothering with a cable.
Yes,i know,but some missinformed people still by the cable.
