Editing P900 original themes ?!
5 replies · 3,106 views · Started 18 February 2004
Hi there,
I would like to edit one of the P900 original themes (classical),
but I didnt found the "utz" file.
Does anybody know where it is ?!
Best regards to all and thanks for any help.
I have downloaded UTZ files online but don't know where they should be placed on my phone. Any help? Thanks
1) a:\system\data\themes\default\classical.utz
Copy it to documents on MS duo and then trancfer to your PC where you can edit it.
2) Place ***.utz file on your phone and then run it. it will automaticaly add file to your themes in control panel
good luck
Hi mixailukr,
I, too, also trying to edit one of the default themes (Blue) but I haven�t got any thing there. I don�t have any directory called as �default� under �c:\system\data\themes� location. Any idea where else it could be?
Thanks in advance.
