I can�t install new themes.
During the installation appears this message:
Unable to install!
compatible with skins series 60 support
version 0.00
Can anyone help me.
Thanks.
Unable to install!
version 0.00
Can anyone help me.
Thanks.
problem fixed.
i have the same problem can you tell us how we can solve this problem please thanks
I just uninstall all the themes that i have in my phone.
This resolve the problem.
Probably was a problem with a Theme. I don�t know.
I'm trying to install themes on my nokia 7650, can anyone tell plz from where to download Series 60 Skins Support?!
hajjash wrote:I'm trying to install themes on my nokia 7650, can anyone tell plz from where to download Series 60 Skins Support?!
ok if i cant download "series 60 skin support" where can i get it from?!
or is it installed certain mobiles like the 6600?! does all mobiles support themes?!
can anyone give me the details plz.. 😊
hajjash wrote:ok if i cant download "series 60 skin support" where can i get it from?!
Only a couple of series 60 phones support themes and the 7650 isnt one of them im afraid mate. :icon4:
does anybody know what are the mobiles that support themes?!
hajjash, there are a few apps available (such as SmartLauncher) which you can install on a 3650/7650. These let you use 'skins' on your phone. Until j2k gets his 'Themerizer' running (no pressure, j2k 😉 ), you'll have to make do with those.
OR, do yourself a favour and upgrade to 6600 - you won't regret it! :icon14:
Those Nokia Series 60 devices currently announced with Themes support: 6600, 6620, 7610, 6260, 6630.
Those available to buy now: 6600, 7610.
does any one know if i can put themes on my n-gage phone??
Unregistere wrote:does any one know if i can put themes on my n-gage phone??
Unfortunately you cant.
Look guys can someone send me the themes which i can use with smart_launcher ... i've got many themes but XP theme is the onLy one which i use with n-gage...the others didnt support it i think... 😎
Sandinista wrote:hajjash, there are a few apps available (such as SmartLauncher) which you can install on a 3650/7650. These let you use 'skins' on your phone. Until j2k gets his 'Themerizer' running (no pressure, j2k 😉 ), you'll have to make do with those.
Hi!
I installed "series60skinsupport.sis",but I still can't install any themes...how Can I install themes to my N-Gage? Why won't nokia fix this problem?😞
No "series60skinsupport.sis" will help; you can't install themes on N-Gage. The N-Gage is based on Series 60 version 1.2 and Themes support first appeared in Series 60 version 2.0. The N-Gage will always remain with Series 60 1.2 = no themes.
I cannot enter the Themes menu on Nokia 6600. When I click Themes icon I stay in the main menu.
I installed some themes like Mushrooms, Ash, etc. Mushrooms theme is active. Could some of these themes have made mess?
Can someone help me? Thanks.
yea it's possible , uninstall theme or apps recently put in (since problem accured)and see if icon works, if still problem could have virus remove by using app FE exployer look in SYMBIAN SECURE DATA thats where i found my old virus,if nothing that's it , but if something post here what and i'll explain next step. 😊
U know maybe we can change our symbian version 1,2 to versin 2,0?! Can we download symbian version 2,0 from net? ....and then to instal it on our phone over old version? I dont know that but maybe somebody know, help us,please!
eneslj wrote:U know maybe we can change our symbian version 1,2 to versin 2,0?! Can we download symbian version 2,0 from net? ....and then to instal it on our phone over old version? I dont know that but maybe somebody know, help us,please!
i have a 7610 and i just installed the newest pc suite and now i cant install themes at all.. example: im trying to install a theme that worked on my phone before via the old pc suite. now it wont be installed at all..how can it be possible??what should i do???
