May i know the available countries code in IMEI's 7th and 8th digits?
And what the differences between CDA 162003/* and 162004/*? If not mistaken the digits after the "/" indicates what?
I almost bought a P900 yesterday.....but found out that the battery was 1000Amh!!!! luckily didn't buy it.
WAT THE PROBLEM WITH 1000MAH??
because the standard one that comes with the p900 is 1250?
but wat is the bad of 1000mAH battery?
because P900 is pack with 1260mAh battery, it means someone replace it by P800's battery.
will u buy a P900 that MSD or battery were replace by someone?? such as 8Mb MSD instead of 32Mb
