PC Suite Alternative
3 replies · 1,578 views · Started 19 February 2004
I have a 6600 and a bluetooth dongle, ik can sent files to and from my pc. BUT I can't get pc suite to work! It worked once and after that nothing, totally nothing. I have tried everything there is to be found on the internet but nothings worked.
Is there an alternative for pc suite? An other program where I can sync my outlook with?
Hope you can help me!
if u r running xp (which i run) this is what i did
first search for devices and click ur phone
and then connect with the serial port
click yes on ur phone
on ur computer it says error
thats ok in about 30 secs u got a pop up down the bottom saying click here to autherise connection
now try ruinning pc suite
it should work
But if by any change this wont work. Are there alternatives? I am at my work right now so I can't try it. (Which I will do when I'm home).
So the questions still stands: Are there alternatives for PC Suite?
And thanx for the rapid responce!
I don't think much of PC Suite either but have yet to find any simpler software that works any better.
You aren't actually having a problem with PC Suite but with the bluetooth connection. Changing the software won't actually help you. You just need to figure out the strange and almost random combination of button pushes and error messages required to get a bluetooth connection!
From a functionality point of view I haven't found any software which does a significantly better job than PC Suite and I have tried. There is a prog called Oxygen phone manager but this was evern worse in my opinion.
