Is there any way of copying the contacts from one Nokia 6600 to another. I have tried to do this using PC Suite but can't get it to work. Any ideas would be appreciated.
Nokia 6600 Contacts
copy everything to the SIM Card! 😊
What I did was make a up back-up of the phone on the MMC, then transfer the MMC to the other phone and restore the back-up. (But the back-up not only included the contacts but also all files/apps/calendar of the other phone) You can also try the bluetooth function (Contact -> Options -> send -> via bluetooth) but you have to do this contact at a time.
try SmartvCard from symbianware
with this tool you can send groups of contacts via bluetooth to another device, a Palm or another 6600.
thedoe!! wrote:try SmartvCard from symbianwarewith this tool you can send groups of contacts via bluetooth to another device, a Palm or another 6600.
Does it also transfer the thumbnails in contacts over?
This software does exactly what you need: Contact Transfer:
Raikee wrote:copy everything to the SIM Card! 😊Just to note that when you can only save one name (single field) with one number and no other details on the SIM, and depending on the SIM something like 150-250 contacts maximum.
Rafe wrote:This software does exactly what you need: Contact Transfer:
Thanks man....u made a good forum here...BTW which country are ppl here most in? I'm from Singapore
Try Contact Manager. You can put all your contacts to one file and send it anywhere.
