Sup peoples, I'm using wav. files from songs as my ringtone on my 3650. But the c drive only has a little more than 3 mb of memory, thus my predicament. I can only have two .wav files (being as each is about 1.2 mb) as available ringtones. All of my MMC card space is of no use to me since I can only select a ringtone from a certain list on the c drive. Is there a program that allows me to pick a ringtone from anywhere i want on the phone?
Ring Tones
Use a file explorer app to create E:\Nokia\Sounds folder and copy the .wav files into it.There'll be available as ringtones then.
Well it wasn't exactly what you said, but close enough for me to figure out. Thank you so very much, you've just made my life that much better.
True.It should be E:\Sounds\Digital
Hey GhostDog, I really ain't too familiar bout Symbian just yet cos I'm waiting for my 3660. So in other words it is possible to select a ringtone off the MMC card, no?
Yes it is,and search the forum,most of you questions are already answered.
is possible,creat a folder at E: as adviced.
