SIS Files for N-Gage
2 replies · 1,988 views · Started 20 February 2004
I have a SIS file for Series60. How can i install it on N-Gage?
When N-Gage is connected i see it as a disk but PC Software which comes with the phone doesn't see N-Gage at all (USB connection is not in the list of supported connections).
You mean pc suite?
Pc suite uses bluetooth. Do a search on the forum this subject had been discussed to death!
Put the .sis on the disk you see on the PC when you connect the N-Gage. It is the N-Gage's memory card (MMC).
Then on the N-Gage use the "Manager" application to install it (scroll the list to the installation file, hit "Options" and pick the obvious choice).
