problem with reply
3 replies · 1,627 views · Started 20 February 2004
when I receive SMS and want to reply, I use REPLAY function,but it doesn't send messages.It's trying,but nothing happens and then I have to search through my contacts to send it back.How can I fix this?
I recently had this problem but with only my wifes messages!
It was solved by changing the 'reply via same centre' option on her nokia 3210 to No.
yeah ,it looks like that it is problem with my network.She is on other one and I'll try to do this.
Thanks!
The "reply via same" message center settings means that if you receive an SMS from somebody else, a reply would go through the orignal sender's SMS center and not your own operator/carrier's center.
If your operator is the same as the sender's, then it works (of course, as the SMS center is the same one).
If your operator/carrier is different, this never (maybe too strong a word, but probably true in 99.99% of cases) works as an operator will not allow some other operator's customers use their message center.
The message is either refused or discared without a trace at the operator side.
So, don't ever use/change this setting.
There may have been some reason for this feature in the past, but today there's probably no practical valid, real-life reason why the feature even exists and is exposed in the user interface.
