Problem: Internal file system
1 replies · 3,519 views · Started 21 February 2004
Hi all,
Please help, I have SE 800 with 64 meg memory card. I tried to copy a mp3 file 29 mb to my phone via IR. I got error message about memory full, restared my phone, now I can't do anything because I 'm getting an error message "the internal file system was found to be corrupted and will now be reformatted" and phone halts, I can't go beyond thit point.
any help will be appreciated
Bassam
I believe you are new at this thing 😉
anyway, you can't beam anything to your phone that is more than the internal space available, as beamed files will be stored in the C drive, otherwise use your Cradle or connect through Bluetooth to copy anything to your Memory Stick
the solution for your problem would be a System Format, which will delete everything you have in your phone! (Sorry)
good luck next time
