orange 6600 *#7370#
16 replies · 5,179 views · Started 21 February 2004
just out of curiousity could anyone tell me pls if i was to do a *#7370# format on an orange 6600 would i loose the orange supplied software update and backup applications ?
yes you lose the lot m8 back your phone to the mem card first,dont forget to take your card out before you format.
Hello,
Could you tell me if I format the phone what will be the results? I mean, I have an Orange soft installed on my 6600 with screen saver, WAP access etc... which I would like to remove. If I format will I erase all this stuff?
And do I need anything else after formating to start again the phone??
The results would be factory reset.The 6600 will be in the out of the box state.You don't need anything else to start the phone again.
Ghostdog,
Which card do you have to remove, the MMR & the SIM or only the MMR before you do the code??
I am certainly doing something wrong, I typed *#7370# without SIM card nor MMR but the only thing which was changes is my theme which reverted to the NOKIA original one. Could youplease tell me what I am doing wrong??
Sorry to bother you again, my question is certainly basic for you, but what is the exact procedure? With the phone ON? OFF? I type that as a phone number???
Thanks, hasta la vista
Plug the charger in(the procedure need a lot of power),remove the MMC,type the code on the main screen(like a number),the in should ask you for the phone lock code,type the lock code press yes and wait.The whole procedure should be over in 1-3 minutes.
Hello Again,
Thanks for your help, it worked. The only problem is that the phone reverted not to the manufacturing standard but to the Orange standard, i.e. Orange screen saver, Orange theme, Orange wap/gprs access etc...
Do you know what should I do to really erase all this Orange stuff??
Thanks again
Cheers,
All what Orange stuff?
The only Orange stuff is the Startup screen and stuff that came on MMC card.
If you dislike Orange so much, then why did you buy an Orange 6600 ? LOL 😃 😃 😃
I am talking about the server lock. I cannot access WAP/GPRS with my other operator, i.e. SFR. It is locked. Of course I use some magnificent themes to customize my phone,
Cheers,
C/S IS THE BEST GAME
Originally posted by dtakias
i have unlocked my orange 6600 with no problems.
Mine is provider unlocked also....no problem at all.
Just use a DCT4 unlocker.
It's not a matter of unlocking the phone. Originally I bought it with Orange as operator, and apperently they laod a soft which manages the WAP/GPRS and only allows you to go to their site. Even if you put another operator SIM Card and you configure the phone with this new operator settings, you cannot access WAP.
I formatted my phone via *#7370# but the phone only reverted to the Orange first definition. I am stucked,
Bon Week-end!!!
I LOVE Counter Strike
