iSync Nokia 6600
3 replies · 2,114 views · Started 21 February 2004
Hi
When I try ty sync my Nokia 6600, telephonebook or calender, to iSync (1.4), I get at the of the syncprocess a message that the memory is full and all post in the telephonebook is not in the Nokia just about 50 - 60%.
Thelepohone file is just 456 k and there about 4,7 Mb in memory. If I import the telephone book from the sim-card is no problem.
What I'm doing wrong?
Lasse T
Sweden
Hi Lasse
I think, there is a size limit in sending files to the 6600 with BT. Try to set only one category to sync with the 6600. Just put some names in it. If it works, try adding all your contacts to this category. And sync only this category.
This was a workaround I hab to use on the P900. Same thing with iCal: Some categries simply did not gor over to the phone.
Wolfgang
Hi Thanks!
I will try during the day and I let you if itworks.
Regfards
Lasse T
Originally posted by wok
Hi Lasse
Wolfgang
if there is a size limit it is not below 13MB as i have sent compressed 3gp files from my powerbook to my 6600 over Bluetooth File Exchange. can't be any different for iSync.
