PC SMS Sending
6 replies · 2,567 views · Started 21 February 2004
Hey y'all,
Just wondering if anyone knows of software that I can use to send SMSs from my PC while the P800 is connected to it (USB or Bluetooth). It seems so logical, I can manage my contacts, upload and download files, go on the net but if I want to write an SMS I have to pick up the phone and use the fiddly (compared to a keyboard) interface!!
If not, why not!!
Ta.
not anymore...
I use RemotePx00 which can be used to emulate your phone's screen on your PC monitor, so you can browse the web, send SMSs, MMSs, even copy and paste stuff from your PC to your phone or vise versa!
you'll get more info and download the trial version fro this link
Remote Px00
Cheers hAnDyGUY. That is indeed a really excellent piece of software, but really what I'm looking for is something a lot simpler.
Just a program I can whack up on screen, type the message and number and hit enter. Even better would be one that can be run from the command line parameters, then I could set-up shortcuts for messages 😊
Originally posted by GhostDog
Try Desktop Message p800.
although some users including myself have experienced it corruptiong the phones sms files
then guess your last choice would be: S&W SMS Folder Manager
check the link:
Handango @ My Symbian
I think it won't allow you to write an SMS from your PC (was that the main topic 😕 ) but it gives you many features reagrding SMSs
