I just bought and installed a Bluetooth USB device for my Fujitsu P5020. My Nokia 6600 and the Fujitsu are paired and communicating, however, when I try to transfer palm callendar data to my Nokia 6600 from the Lifebook and error message is displayed "Framework for Symbian Connect 7 has encoutered a problem" Does anyone know how to fix this? Thanks.
Nokia 6600 Symbian 7 Connect problem
i dont think those 2 calendars work the same, u cant use a windows app on a mac, and u cant use a palm calendar on a nokia 6600
I have the same problem... I can't use my file transfer...
I use a 6600 with Windows XP, so no Mac
