i hav some mbm file
but they are not opening in my pc
in which program they are to be open
and i have 500mhz pc and nokia theme editor is unable to install in my pc
tell me wht should i do
i hav some mbm file
You can edit mbm files with XnView.Search google for it.But if your purpose is theme development i don't think it will do much good without theme editor.
Vicky, I have made a tutorial on this subject allowing you to open and view existing themes to save their icons and other components.
I have attached it for you. It is a Word document with pictures as well.
It is posted on various sites, PM me and I'll give you the URL's.
Ian
I installed Xnview and I can't seem to open the .mbm files I would like to open.
Can anyone here help me?
