Gallery displays incorrect thumbnails
4 replies · 2,109 views · Started 22 February 2004
When viewing the gallery, the incorrect thumbnail is displayed next to the file names. Some thumbnails are mixed up, and some are just duplicated onto different filenames.
Its very annoying, especially when you have non-descriptive filenames.
I deleted the thumbnail directory on my MMC, but it seems it just keeps happening.
Anyone know what causes this or if there is a fix or workaround?
Any help or input is appreaciated.
I had this,but only with freshly downloaded images,does it still do it after you view the pics?
go tho the folder where the images are stored and delete the thunmbnail subfolder in it.Next time you open that folder the thumbnails will be generated again and everything will be fine.
If you read my original post correctly I said I have done that and it makes no difference. They just swap around again.
