does not save
4 replies · 1,468 views · Started 22 February 2004
hi
i have a 3650 and wen i download mp3s on my phone..obviously the file goes to the inboox thru the ir port..but wen i try to open the file...this msg is displayed
messaging:
fomat not supported
help?
i have the player i have the converter..how the hell do i save it on the phone..!!
iy saves wave files..but i want mp3s as they are much smaller in size.
i save wav files and when it saves it to the phone it is about 900kb for a 3min song. But you need to upload it using nokia phone suite as this compreses the file as well.
To compress it even more use Goldwave this converts from mp3 to wav. Hope this is not to confusing
ok i got seleq..i think wat u want me to do..is copy files from inbox to any folder..but it does not show inbox anywhere..everything except for inbox is displayed..and theres one option where it says edit:copy inbox..on clicking that it shows system error.
hi..
thnx for the help
it worked..
im using mp3go trial software..which plays only the first one minute of the song..can u tell me abt any free softwares which will play the entire song.
