System Error message
6 replies · 2,254 views · Started 22 February 2004
I keep getting a system error message when I start my phone or open any new application. I tried starting my phone in safe mode and that didn't work, and i also tried reseting my sim card with #7370# but i get a message saying "Request not completed". I'm pretty sure my phone messed up after I put wildskinz on it. does anyone have a solution for my problem?
Wildskinz is the problem.
Uninstall wildskins - be sure to deactive it first.
If you have already uninstalled it then you did so without deactivating it.
Reinstall it
Activate
Deactivate
Uninstall
Your phone will now be fine.
Will
hey thanks a lot for the help. Once I reinstalled wildskinz and then turned it off my phone was fixed. I really appericate the help.
Ni+Mh,i know that you are new but search the forum.Recycling threads is not exactly allowed.Anyway,you can find more info about wildskins on www.wildpalm.co.uk .It a bugy skining applications that has caused many problems.
