Hi All.
I HAVE SOME SMALL VIDEOS ON MY MEMORY CARD WHICH I CREATED USING MOBICLIP, QUESTION IS IN WHICH FOLDER DO I PUT THESE CLIPS IN IF I AM USING A MEMORY CARD READER. I HAVE INSTALLED MOBICLIP ONTO MY PHONE AND MEMORY CARD, PLEASE HELP
Hi All.
Try E:\mobiclip and please don't shout! 😉
I am sorry but i didnt understand what you meant by try e: there isnt a folder on my memory card such as that.
Let me clarify,create a folder named mobiclip in the root of your MMC and put videos there.
do you mean in the system folder, if that is what you mean then there is a folder already called mobiclip
You shoud've read the manual but anyway.No,i don't mean the system folder.There should be a folder called mobiclip in the root/toplevel of the MMC.Other folders you can find there are Nokia,System,Sounds etc etc.If you browse the file system with a file explorer the MMC will be labeled as E:\ .If you have a file explorer you can locate the .mo file clicki and mobiclip will automaticaly start.
azzy wrote:Hi All.I HAVE SOME SMALL VIDEOS ON MY MEMORY CARD WHICH I CREATED USING MOBICLIP, QUESTION IS IN WHICH FOLDER DO I PUT THESE CLIPS IN IF I AM USING A MEMORY CARD READER. I HAVE INSTALLED MOBICLIP ONTO MY PHONE AND MEMORY CARD, PLEASE HELP
Hi azzy i just wanted 2 no if ur real name was john hazlit or howerver you spell ur second name if u r john because if u r i think i know u
from
It seems there is a new version of Mobiclip on www.mobiclip.com.
V.
