Extended Profiles Pro 'working days' doesn't work
2 replies · 2,732 views · Started 23 February 2004
When you setup a schedule for working days it just doesn't activate the profile. Select every day or selected days and tick mon/tue/wed... and it works fine. I've even tried changing the date on the phone, still doesn't work.
i agree to that but it doesn't bother me at all, but it should be fixed by the next version!!
Eprofiles 2.02, if you set filtering( allert for several groups) for specific profile, it won'work?! I had bad expiriense with call during the night, nevertheless the profile was set to filter some calls. If I use the manual profile switch, the filtering works like charm. Any ideas?
