transfer files to \system\apps\ folder
2 replies · 2,444 views · Started 24 February 2004
Hello !
With which tool can I transfer files into the \system\apps\ folder and how can I locate this folder ?
With the built in filemanager I cannot see the system folder.
Thank you
Use Seleq or FExplorer.
It's like windows explorer on your pc. You can go around with your files, copy, edit, rename, cut, paste, etc.
Good luck!
