hi there,
anybody here have read the BTObjectExchange example from the sdk documentation? i'm currently use the serverside from the example to receive obex object transfer.
if u had, i want to ask about how to make the bluetooth digital pen connected to the application?
here is the example code
void CObjectExchangeServer::ConstructL()
// create OBEX object to receive obex transfer
iObexBufData = CBufFlat::NewL(KBufferSize); iObexBufObject = CObexBufObject::NewL(iObexBufData);
iAdvertiser = CObjectExchangeServiceAdvertiser::NewL();
void CObjectExchangeServer::StartL()
TRAPD(err,InitialiseServerL());
if (err != KErrNone)
iLog.LogL(_L("Failed "😉,err);
DisconnectL();
void CObjectExchangeServer::InitialiseServerL()
if (iObexServer)
ASSERT(IsConnected()); // server already running
return;
// Get a port to listen on
TInt channel = AvailableServerChannelL();
SetSecurityOnChannelL(EFalse, EFalse, ETrue, channel);
// start the OBEX server
TObexBluetoothProtocolInfo obexProtocolInfo;
obexProtocolInfo.iTransport.Copy(KServerTransportName); //KServerTransportName = RFCOMM
obexProtocolInfo.iAddr.SetPort(channel); //Port
//creates a CObexServer session with the OBEX server,
//and calls Start so that it starts listening for incoming connections.
iObexServer = CObexServer::NewL(obexProtocolInfo); iObexServer->Start(this);
// advertise this service
iAdvertiser->StartAdvertisingL(channel); //port nya di advertise
iAdvertiser->UpdateAvailabilityL(ETrue); //adds a Service Availability attribute to the SDP database
iLog.LogL(_L("Server started"😉);
TInt CObjectExchangeServer::AvailableServerChannelL()
RSocketServ socketServer;
User::LeaveIfError(socketServer.Connect());
//Provides the Connect() function to create an IPC communication channel to the socket server
CleanupClosePushL(socketServer);
RSocket socket;
User::LeaveIfError(socket.Open(socketServer, _L("RFCOMM"😉));
//parameter(server, name of protocol)
CleanupClosePushL(socket);
TInt channel;
User::LeaveIfError(
socket.GetOpt(KRFCOMMGetAvailableServerChannel, KSolBtRFCOMM, channel)
// found the port can now close the socket and the socket server
CleanupStack::PopAndDestroy(); // socket
CleanupStack::PopAndDestroy(); // socketServer
return channel;
i also use MObexServerNotify, but why TransportUpIndication() is not working?
void CObjectExchangeServer::TransportUpIndication()
//A OBEX connection is requested over Bluetooth by the sending device
iLog.LogL(_L("Connected"😉);
anyone can help me? thanks
Rx-
