can this camera http://www.mobilefun.co.uk/product/2007.htm work with the n-gage, and is it worth it?
if not where is a decent one?
are the blue tooth wireless headsets worth the 30-50 bucks or not? and if you get the headset do you need to get one of those big, square-ish chips to plug into your n-gage,
also have any of you seen any decent n-gage covers, the only decent one i've seen is the black one, and is that good quality?
Had a look at the camera and the answer is no. If you have a look further down the page it has a list of compatible phones and the n-gage is not in it. If you are itching to get a camera. Any 2 megapixel camera will be better than most mobile phone inbuilt cameras and you can get really tiny ones now. You could get one with bluetooth and have it send the photo straight to your n-gage, but bluetooth cameras are a little expensive. Otherwise you can get a camera witch uses mmc's and once you have taken photo pop it into n-gage and view the photos.
As for the bluetooth headset the n-gage requires no extra addons to use the headsets. All you need is the bluetooth headset.
As for n-gage covers I think allack are quite good and have been mentioned round the forum a few times. As for the quality of the covers i am sure its pretty good but can not confirm this since still got the original n-gage cover.
Hope that helps
so whats a recommended small 2 megapixel digital camera, and which bluetooth headsets are reccommended
As far as the camera goes it is up to you what you want have a look around and see what is available and see how much cash you want to spend on it. Try Amaxon they are pretty good sometimes. The headset I recommend is the Jabra BT200, but again look around see what features are most important to you. The best price for the Jabra headset was at amazon IMHO.
as for camara i sugest yuo go for a good quality camara whit a mmc i have a kodak 3.1 that uses digital and multimedia cards and i use the 64mb memory card i boutgh for the n-gage to take snaps of my friends to put on the thumbnail
didnt even change format :P
definetely buy Minolta DImage X,Xi or Xt...You can buy used one on ebay for about 100 pounds.And it's really worth it!!!
