How should i install real player advanced? Should i install it to the phone memory or the memory card? Do i
need to uninstall the original real player that came with the 6600 before i can install the newer version?
When i tried to install the advanced one to the phone memory without uninstalling the other one, it didn't
play the .rm videos. What should i do to make it play all my .3gp and .rm videos? Pls help. Thanks in advance!
installing real one player advanced...
I don't think u can uninstall the original realplayer. i would imagine the new 1 will replace the other 1 so u should install it on the phone memory but since that doesn't work properly u could try it on the mmc card that way u'll be able to use both because real1 is on the phone memory. Hope that helps.
btw can u tell me where u got the real player advance?
