Hey,
When I bought my phone, it had a trail version of Photographer on. I didn't really use it so deleted it. I now recently heard that taking photos with photographer makes the quality better. Is this true? Does anyone have any examples? I don't want to install some program that just takes up memory if it doesn't really do anything...
HI!..
Yes ... both third party apps... Photographer or FlexiCam for example take better pics than the default nokia app..
Mostly because you can get a less compressed (higher quality) JPG or even save on BMP formats...
Cya!
Aefox, where can we download even the trial version of those apps?
Please post the url.
Thanks a lot!
raL
There's Photographer, FlexiCam and CameraFX - which is the best, and why? Which should I (we) shoose?
-kris
Search,there are couple of lengthy discussions on the subject.
