Where can i get Nokia Theme Edior 1.0. I've checked out some but i couldn't find it.
thanks for your help.
I'm sure it's been posted before and the mods don't like posts of the same questions over and over.
Please next time try a search first, just incase.
Go here mate :
http://www.forum.nokia.com/main/1,6566,030,00.html?fsrParam=2-3-/main/0,6566,030,00.html&fileID=4003
This is Nokia's Theme Studio to download, it's 22.6Mb so be ready for a wait to get it unless you have broard band maybe.
You may need to register, don't worry it's free so just do it for access to loads of SDK's and stuff.
Ian
i got it..
thank u very much.
I'll search for my question b4 sending a post.!
Brilliant! Your very welcome mate.
I'll be waiting to see what nice themes you produce 😊
Ian
Hi, I was just wondering is there an xp version of the 6600 theme maker coz I tried to install it and its not compatible, hope you can help, thanks,
Terry
Originally posted by tjc524
Hi, I was just wondering is there an xp version of the 6600 theme maker coz I tried to install it and its not compatible, hope you can help, thanks,Terry
If you "right click" on the program and select the bottom point (not sure what it's called in english) you will get a new window and the middel index should read "System compatibility" select that and you should be abel to switch the compatibility to include Windows 2000 or what ever i needed
Hope It makes scence 😉
N.E.R.D
Originally posted by N.E.R.D
If you "right click" on the program and select the bottom point (not sure what it's called in english) you will get a new window and the middel index should read "System compatibility" select that and you should be abel to switch the compatibility to include Windows 2000 or what ever i neededHope It makes scence 😉
N.E.R.D
Thanks for your help with that, one other question though can you put videos in as screensavers or backgrounds with theme editor,
Terry
No mate!
