MobiClip Converter where can I get it.
8 replies · 7,563 views · Started 27 February 2004
Ok after trying out pv video player and playing movie in full screen I don't wana go back to using real player. I've got pv author but can't get the videos to a decent quality and seeing as nobody seems to want to tell me what settings to use i've decided to look at mobiclip as it also allows full screen playback. I've downloaded the player but can't find the converter on the site anywhere the only way i can see how you could get it is to sign up as publisher. So basically can somebody tell me where to get it from??
Also what other players are good I've heard about the other fullscreen player is it smart player or somethnig but heard the files ae massive. Anyway somebody please help any help will be apprichated (spelt wrongly).
O yeah any body that wants my collection of music videos in real format I've posted them at www.geocities.com/phonevids
Somebody help me plz.
You need to sign-up to get mobiclip convertor,sorry.
SmartMovie files are not massive,they are quite normal.
Please remove the link if there are any copyrighted videos on the website you posted.
O rite can I sign up or not?? Can some one not just post a link to it?? I'm just trying smart movie now seems ok just encoding a video so we shall see what its like. I'm pretty sure those video's are not copyrighted.
Bert,i just checked mobiclip's website - www.mobiclip.com and it seems they've removed the free beta so the only way you can download the convertor is by becoming a licensed publisher of mobiclip content.
O rite that really is gutting, im haveing a look around the net for the beta version but am not having much luck.
Also does anyone know the best settings for smartmovie??
The higher the better. Its a trade-off between size and quality. Also the more action the movie has the higher you idealy want the bit rate to be so that fast action scenes dont pixelate.
Dont you think mobiclip are shooting themselves in the foot by not allowing simple users to encode there videos. Well we shall see!
samrt movies are less than mobiclips, at least for me. (when using same settings) mobiclip is normally 3 times bigger than any .rm files, and is a more labored process than smart movies(seeing as you have to use virtual dub)
Well,it depends on the bitrate of the files,but i guess that xvid (smart movie) files are smaller.I still think mobiclip is better because its the only one that can play 24fps movies without skipping.
