changing the passcode
5 replies · 2,071 views · Started 28 February 2004
Well guys!
I`m trying to connect my 7650 to my pc.
The problem is the PASSCODE.
Ok, i know that they have to be the same on the cel and on the pc.
BUT, when i try to connect, the 7650 prompts, "Passcode for PC".
This means that my pc already has a passcode, but i dont know what is it and where can i change it!!
HELPPP!!!
OK!!! I GOT IT! :P
now i can upload files from the computer to my nokia.
But when i try to upload from the nokia to my pc, it says "Sending failed!"
What is the problem??
Search the forum for a solution,there is a big thread on the subject or just update the bluetooth drivers on you PC to the latest version - 1.3.x , 1.4.x
I used to have same problem, but i have a wincomm BT009V
downloaded latest drivers from online (v1.3.7 for me)
and all works 100%, seems as there was a Protocol issue with earlier versions
So what ever bluetooth dongle u have , get latest drivers
