Problems with Doom...
4 replies · 2,098 views · Started 28 February 2004
Hey guys.
Like just about everyone else, I can never get Doom to work correctly on my N-Gage... The sound never seems to work. It's not because I don't have the driver, because I installed both Wildpalms Stackup and Terra Force games, (which doom recognises and allows me to select sound on) and it still doesn't work...
The odd thing is though, the sound actually DID work for about a day there, the first time I installed Terra Force. Since then however, it's never worked since... and i've deleted/reinstalled Doom/Stackup and Terra Force several times... which brings another question... when i'm deleting the programs, do I just delete the folder in the APPS section? or are there some other files located elsewhere? I noticed a few "doomrender.dll" and others I deleted, as well as the install shortcuts, but I don't know if it was fully uninstalled or not.
Any help anyone could provide would be greatly appreciated. Thanks.
Looks like I solved my own problem.
I found if you install this version of doom it works... (all files located within the one file, instead of several.)
removed
