Can you change the location of where beamed files are sent to e.g. to the d:\ instead of c:\?
Beamed Files
u cannot send to the d: drive. However you can change it to the e: drive (ur memory card) by simply going onto settings (while in messaging), going to 'other' and then changing the location to memory card.
sorry only just realised this was the p800 forum, i thought i was in the series 60 part.
as sco2001 said... you can't, beamed files will remain in the C drive till you move them
you can find beamed files in the C:\System\Mail\
then u'll need to search for the file through available folders (you have to check each folder!
