Hi everyone, i got doom on my phone as these installation files:
DOOM.sis
doom-core1.sis
doom-core2.sis
doom-sounds.sis
doom-lev1.sis
doom-lev2.sis
I remember that i have to install these in a certain order but i can't fine the site where i orignally got the game from. Can anyone tell me the order in which to install them. Thanks
i think im not sure but its at www.wildpalm.com
I copied the instruction readme txt for ya.
_____________________________
Doom 7650 v1.2 Install Instructions
Doom 7650 is split into several .sis installation files, in order to aid installation.
Doom 7650 does require a large amount of memory for installation, and the installation will not
work correctly if there is less than approximately 2000K of free space on the phone.
The files are as follows - please install in the following order:
doom.sis - Main application
doom-core1.sis - Main data file, part 1
doom-core2.sis - Main data file, part 2
doom-sounds.sis - Sound data (optional - sounds will not play if not installed)
doom-lev1.sis - Levels 1-4 & 9 (optional, if doom-lev2.sis is installed)
doom-lev2.sis - Levels 5-8 (optional, if doom-lev1.sis is installed)
If any component is removed, all of the .sis files will need to be installed again.
The data files have not changed in this version - if upgrading from a previous version, only the doom.sis file needs
to be installed.
Sound can be enabled by installing one of our other games, which come with the required sound driver.
This version does not support Deathmatch play. Deathmatch over Bluetooth will be supported in a future version.
WildPalm Team
[email][email protected][/email]
www.WildPalm.co.uk
________________________________________
Hope this helps!
Thanks i installed it, but now i get a message saying Data files are missing, see help for details, i followed the instructions just like it said.
if youve installed them to your mmc, youll need the patch.
In the future,search the forum,it has been posted a couple of times already but anyway,here it is.
installed it to my phone memory works fine now
i cant find it..., i think its no longer available in www.WildPalm.co.uk, any more source??
if i put play it says App.closed EDOOMEXE KERN-EXEC 0,buytheway does it work on 3650
