Anybody here knows how to send RINGTONE (.rng) files from the 9210i Communicator to another phone (preferrably nokia) such as in SMS, or as in attachments? 😱
Is there any software out there? for sending ringtones from the communicator to any other nokia phone in rng format maybe.
I need a method other than IrDA because I don't have the phone, its my friends phone and he lives someplace else.
My friend used a cheap $50 Nokia 2100 to send me ringtones in the nokia ringtone format (.rng), so I guess this $600 Nokia 9210i can do the same?! Hope so! 🙄
�awyeah�
Using file explorer go to the folder where you keep your .rng files.
If you do not know where to find them use the Menu>Tools>Find feature.
Then after selecting a file use menu>file>send as Message feature....
It was there, it is not?
Now you can spam your friends 😊
i think you got the answer to this already awyeah - its either ringmaster or mystyle right 😉
neewp... mystyle neither emessaging, or ringmaster sends, ringtones.
the procedure in reply, to my thread, posted by thespecialboy is good and works for me.
kthx
awyeah
