hey every one well i have a nokia 6600 and i can't transfer my *.eye file from the fone to my pc which is larger than 8 MB . fone givin out error like delete some appz first not enough memory to perform the operation and secondly suggest me any good player for *.eye to play my *.eye filez on pc
suggest player for *.eye and solve my pro also
You shoul've searched the forum but anyway you will need EYECON GUI to play files on PC.
ya i already searched the forums and got the gui converter which convert .eye to .avi but it doesn't work on my pc.....i mean it tell that ur movie has been converted but no file was found where i choose to save my avi movie ......in short it doen't convert the clips.....and second problem which i got i m not able to transfer my .eye files which larger than 3 min to my pc....well help on this also and thnx for ur help allaboutsymbian userz u doin a great job
Make sure you are using GUI 1.1 as it fixed most occurances of the problem you are experiencing which were present in 1.0.
