About service (o2,t-mobile etc)
6 replies · 1,779 views · Started 01 March 2004
😊 Hi everyone,
😞 Help me, which best service for when my office at basement, my mob is nokia 9210i cant use service with Orange,
Can anyone tell me who can service at basement?
im grateful if any one help me,
cheers
Dunko9
Wirelessly posted (Nokia6600/1.0 (3.42.1) SymbianOS/7.0s Series60/2.0 Profile/MIDP-2.0 Configuration/CLDC-1.0)
Could you be more specific ? I did not get your question.
ok sorry im not very good english!!, i mean when im work at basement of building, my mob is no service (like ariel), when im at ground, its working service, u know i mean?
i use with Orange is crap! but other like o2, t-mobile which best at basement will working service?
hope u understand?
cheers
Dunko9
1. Try to open the Phone ANTENA.
2. Speak with Orange Customer support and tell them that you do not have signal in that area. They should react and increase the signal area, so that you can work happier 😉
Try with the antena extended. It should work.... If Orange says they cannot increase signal area in your working place....i am affraid you should change GSM Operator.....
It is a petty that 92xx does not have an external antenna plug. This would have solved a lot of signal issues.
same here where buildings are like bunkers (not the toughness though) and relay stations are not very frequent - 9210i antennae do not help much 😞 and even bigger problem is that there is only one provider here in SA 😞 😞
