Just need some clarification before I change to N6600 from N7650. I always run out of memory.
1) does installed program goes into MMC?
2) can we tranfer program to MMC and still run them like Palm?
3) data files in MMC can be accessed directly?
Thanks!
1. u get to choose
2.no only on seriers 60
3. yes through a program called feexplorer
If you are asking whether or not you can run Palm applications the answer is no but if you are asking whether you can transfer an application to the MMC and run it from the MMC the answer is yes.
Sorry, I was not very clear.
It was the ability to transfer pgm to the card and still run it.
Thanks!
Looked like I am nearing a decision to get n6600. How I wish there is a chinese os so I can surf chinese website as well.
