NEC memory card
3 replies · 1,316 views · Started 02 March 2004
hi
i am getting a 256 mb memory card by some company named NEC. for about 90 us$. can any body tell me if its fully compatible with nokia 6600 or not?? is it worth it??
thanks cheers
Is the memory card an MMC card (MultiMedia Card) and not, e.g, an SD card (Secure Digital card)?
If it is an MMC card, it should work (any MMC card should work, but always they don't due to implementation differences, manufacturing quality differences or whatever).
You can search for existing threads that list tested MMC brands and sizes for various Series 60 phones. The search function is here: http://www.allaboutsymbian.com/forum/search.php?s=
ofcourse its a mmc and not SD.
i wanted to does it do everything like the orignal mmc supplied by nokia?? i mean this NEC one k
thanks
shahid104,like N/A said,search.In the 6600 forum there is a big sticky thread named "Tested MMC cards".If your NEC MMC has been tried by anyone it will be listed there.
Thread closed.
